Who was looking for frame bolt hole plugs 4 digit
1755
07-12-2006 16:52:03
I thought there was someone talking about trying to find those plastic bolt hole plugs on the culivator mounting pads on a 4 digit I notesed the other day at work that the plugs that that I think they use to plug the dipstic hole on GM transmitons is the same sise and the only diference is the color blue insted of green but you have to find a salvage yard that sends out alot of trans and they put them in or a trans shop that has some I dont know if they can order them or not I work in a converter shop and there are a few ods and ends that I see every once and awhile but no fersher acses to them but maby there is a shop in your area
