Power steering pump??
550Doug
07-27-2006 15:07:58
Grass cutting the other day and my power steering made a slight sound and "let go" with a slight increase in rpm. No more power steering! I've removed the Vickers pump and the pulley moves real free in both directions, with the occasional grind when turned backwards. Is it possible that the pump is ok and that the steering wheel assembly is at fault? Are there overhaul kits available?
Tractor is a Cockshutt 540.
Thanks
