1650 Engine Serial #
88 Puller
08-21-2006 10:16:43
I have an 88 RC with what I believe to be a 1650 engine in it.
On the right side of the engine, on the cast boss below the alternator is the # 158628A
Is this an engine serial number for an engineout of a 1650?
Jim
rp1555
08-22-2006 15:01:24
 Re: 1650 Engine Serial # in reply to 88 Puller, 08-21-2006 10:16:43
158544AS is the part # for a early style 1650 diesel
rp1555
08-21-2006 18:48:48
That is the alternator bracket part #. The engine serial # is below that running vertically. The engine serial# won't tell you much. You need the casting # behind the starter to tell the model it fits.
88 Puller
08-22-2006 09:15:44
 Re: 1650 Engine Serial # in reply to rp1555 , 08-21-2006 18:48:48
There are three numbers above the starter in the engine casting in the order below:
221320
158544A
928A
Is this any information on the engine?
