Oliver 770 value?
1855man
08-23-2006 20:49:12
Hi, fellas, was wondering how much an oliver 770 gas narrow front is worth. It has been setting in a barn since 1999. It has a two row New Idea corn picker mounted on it. I dont really want the picker just the tractor. It is the newer style 770 with the grill with the square holes. the tin is in excellent shape. It turns over real well but isnt getting spark. Havent messed with it yet but maybe you could give me a suggestion as to what the problem is. Your input is greatly appreciated
evielboweviel
08-24-2006 17:39:52
 Re: Oliver 770 value? in reply to 1855man, 08-23-2006 20:49:12
where is this picker located at??
Ron
1855man
08-24-2006 21:37:48
 Re: Oliver 770 value? in reply to evielboweviel, 08-24-2006 17:39:52
The picker is located 20 miles from erie pennsylvania
evilboweviel
08-25-2006 03:52:06
 Re: Oliver 770 value? in reply to 1855man, 08-24-2006 21:37:48
270 miles one way a little farther than I wanted to go. Hopeing it might be close enough to drive the tractor there and get the picker
Thanks
Ron
old
08-23-2006 21:19:14
No spark and it has sat that long thats a thing that is simple. It needs new points and condenser plus probably a cap and rotor. As far as worth well it could be $300 up to $5000 all depends on tires sheet metal etc. ,etc.
