Need source for Super88 parts
ACEd
09-05-2006 07:18:11
I have a Super88 Diesel that needs new grilles - looking for parts or best source for parts - had been told same as 77, 88, Super77 - can anyone confirm this? Also need one of the U bolt like pieces for 30 inch rear wheel. Good reproductions would be OK. Thanks, Ed
SherryS
09-05-2006 07:35:23
 Re: Need source for Super88 parts in reply to ACEd, 09-05-2006 07:18:11
The 88 grill is NOT the same as the 77. The 66 & 77 use the same grill. The 88 and 99 use the same grill. Check with Korves Oliver parts. They handle just about everything for that series.
D-Day
09-05-2006 08:12:50
 Re: Need source for Super88 parts in reply to SherryS, 09-05-2006 07:35:23
You're only half right. The 66 & 77 do use the same grill, but the 88 and 99 are not the same. The 99 grill is wider.
oliver fan
09-05-2006 08:20:44
 Re: Need source for Super88 parts in reply to D-Day, 09-05-2006 08:12:50
D-Day, You may want to re-think and repost your statement about the 88 & 99 grills not being the same.
D-Day
09-05-2006 08:23:23
 Re: Need source for Super88 parts in reply to oliver fan, 09-05-2006 08:20:44
I know the center grill stip is wider on a 99, maybe I thought the grill itself was wider as well.
SherryS
09-05-2006 10:37:41
 Re: Need source for Super88 parts in reply to D-Day, 09-05-2006 08:23:23
The 88 and 99 grills ARE the same. They use a different center grill strip which makes the 99's look wider. It's a common misconception that many people have.
