waterproofing a masonry chimney top
550Doug
10-16-2006 15:06:23
What are the recommended products to seal and waterproof the concrete top of a 4 flue chimney? The concrete was poured about 6 weeks ago and now I want to prevent water from penetrating and freezing. Does the presence of heat affect a regular sealer? Would roofing tar be ok? Thanks
oliver28472
10-17-2006 06:21:36
 Re: waterproofing a masonry chimney top in reply to 550Doug, 10-16-2006 15:06:23
I put dry lock on my 2 flue chimney. It's basically portland cement and rubber. Same thing on the inside of my basement walls. Has been up there for several years with no problems. It is pretty thick and is white in color. The mud cap was all that was painted and it needed it pretty bad.
farmall fanatic
10-17-2006 04:35:26
what are you doing making a incinerator for popin johnies
BigMarv1085
10-16-2006 17:25:55
Thompson's water seal makes a rubberized paint that bonds real well to concrete. Used it on my parents chimmney cap.
