Where is Super 88 Diesel Engine s/n
ACEd(La)
11-17-2006 18:42:47
Looking for engine s/n - need help - where to look on 1956 S88 Diesel. Thanks, Ed
J. Schwiebert
11-18-2006 07:58:04
 Re: Where is Super 88 Diesel Engine s/n in reply to ACEd(La), 11-17-2006 18:42:47
Engine serial number is loacted on right rear motor flange. It is a long number. On your oil filter question. Original filter base takes 2 filters/ When the better quality filters were put on the market a single filter was used. Many were converted. More questions?J
ACEd(La)
11-18-2006 16:57:04
 Re: Where is Super 88 Diesel Engine s/n in reply to J. Schwiebert, 11-18-2006 07:58:04
Still can"t find it - I assume drivers right and side of engine block at aft end running up and down just above engine mount. I found a flange where motor block mounts to trans bell housing - but no numbers. Found a set of casting numbers on left of block 104305A 190320N and 3170
ACEd(La)
11-18-2006 08:38:53
Thanks - I"ll look for it today - any idea on when change was made to single filters - I have a feeling motor may be more recent than tractor which is 1956 - but I"ll know more later today as I have build card that shows motor no s/b 1002156.
