1950 Hyd System
1950Md
11-28-2006 05:34:56
I fill hyd system to full mark,power steering works,three point and wet lines all work. The next day when I check fluid it takes 2 gallons to fill system. I need some ideas on how to solve this problem. Hyd oil is pricey in MD.
learned
11-28-2006 09:31:38
 Re: 1950 Hyd System in reply to 1950Md, 11-28-2006 05:34:56
If you find rear end overfilled the problem will be the seal around the draft control rod or pump shaft seal
