1950 hyd system
1950 MD
11-28-2006 06:20:32
Three point,power steering and wet lines all work good.But every day I use it I have to put 2 gallons of hyd oil in system. Need some ideas on were to start on how to fix problem. Hyd oil is pricey.
Richard Jagels
11-28-2006 06:54:14
 Re: 1950 hyd system in reply to 1950 MD, 11-28-2006 06:20:32
My 2-105 had a problem like you are having. The seals in the PTO unit were leaking and putting the hydraulic oil into the rear end case. So check the rear end and if it is over full you know the problem!! Good luck, RJ
