1950 Hyd
1950 MD
11-28-2006 07:46:02
Three point hitch,power steering,and wetlines work ok. Everyday I use the tractor I have to put 2 gallons of hyd oil in the machine. Need some ideas on were to start on how to fix the problem. Hyd oil is pricey.
Leob
11-28-2006 19:55:45
 Re: 1950 Hyd in reply to 1950 MD, 11-28-2006 07:46:02
I once had this problem with a 1950. The hyraulic fluid was spilling into the rear end. Turned out to be a bad hydraulic pump. Have you checked your rear end fluid?
1950MD
11-28-2006 16:51:44
It got posted so many times because I didn't think it was working. I filled the system today and worked the tractor will check tom. to see the level of hyd oil.
J Schwiebert
11-28-2006 13:25:05
O. K. Why did you post this so many times? You have one of three problems. The draft rod shaft seal leaks. 2. The front seal on the hydraulic pump leaks. 3. You have a bad axle bearing and the bull gear is rubbing a hole in the hydraulic pan. It is not your PTO as you do not have a hydraulic engaged PTO clutch. Will the hydraulic oil leak out say overnight if you don't use the tractor?
1950MD
12-03-2006 15:51:31
 Re: 1950 Hyd in reply to J Schwiebert, 11-28-2006 13:25:05
J. if the tractor had a bad bearing in rear end would'nt it be making a fuss. The good side of this is when I get all the bugs worked out I should have a decent tractor.
