2255 injectors
Adam Suess
11-30-2006 18:10:41
The injection pump on my 2255 with 3150 engine is bad. Tractor has 5100 hrs. Would it be worth the while to check the injectors as well or are these good for longer? The tractor does smoke black and I'm told that is not normal for a stock 3150? The air filters are clean.
B A Star
11-30-2006 21:00:30
 Re: 2255 injectors in reply to Adam Suess, 11-30-2006 18:10:41
Adam:
   It has Rossa Master pencil type nozzles.  They are somewhat different from the type you normally see.  They do not have the bleedoff return lines.  Test proceedure is different.  Your Diesel Pump shop will be able to handle them or offer replacements.
