1951 Oliver 77 steering shaft bearing replacement
AB
01-18-2007 22:09:18
third party image
The brass bearing was wore causing sloppiness.
nballen
01-19-2007 10:05:23
 Re: 1951 Oliver 77 steering shaft bearing replacem in reply to AB, 01-18-2007 22:09:18
Nice photo essay. You make it look so easy!
Nathaniel
AB
01-18-2007 22:10:35
third party image
You must also take apart below the radiator.
AB
01-18-2007 22:11:50
 Re: 1951 Oliver 77 steering shaft bearing replacem in reply to AB, 01-18-2007 22:10:35
third party image
Dismantle the bearing holders.
AB
01-18-2007 22:12:57
 Re: 1951 Oliver 77 steering shaft bearing replacem in reply to AB, 01-18-2007 22:11:50
third party image
Disconnect the front shaft.
AB
01-18-2007 22:13:54
 Re: 1951 Oliver 77 steering shaft bearing replacem in reply to AB, 01-18-2007 22:12:57
third party image
Disconnected.
AB
01-18-2007 22:15:12
 Re: 1951 Oliver 77 steering shaft bearing replacem in reply to AB, 01-18-2007 22:13:54
third party image
Remove half moon key from other end.
AB
01-18-2007 22:17:48
 Re: 1951 Oliver 77 steering shaft bearing replacem in reply to AB, 01-18-2007 22:15:12
third party image
Comparing old to new. Notice NOS part when White and New Idea were together. Your AGCO dealer or favorite specialized Oliver reproduction parts supplier should be able to get you this part.
AB
01-18-2007 22:19:15
 Re: 1951 Oliver 77 steering shaft bearing replacem in reply to AB, 01-18-2007 22:17:48
third party image
You must smooth down the shaft to get the new bearing on. I used fine emory cloth.
AB
01-18-2007 22:20:22
 Re: 1951 Oliver 77 steering shaft bearing replacem in reply to AB, 01-18-2007 22:19:15
third party image
Task completed!
Larry NE IL
01-19-2007 15:08:02
 Re: 1951 Oliver 77 steering shaft bearing replacem in reply to AB, 01-18-2007 22:20:22
That was impressive!!
Thanx
