4-180 articulation bearings
AGCOGUY
01-22-2007 19:32:25
Just wondering if someone knew of a cheaper source than AGCO for these bearings..Tried NAPA as well..they were actually higher than AGCO..any help would be great
davpal
01-23-2007 22:41:17
 Re: 4-180 articulation bearings in reply to AGCOGUY, 01-22-2007 19:32:25
If you can find one in a salvage yard that is split in half I would go for a used bearing and pin assemble or just the bearing. They are usually good or bad and not much in between so if you get a good used one you should be fine for years.
e
01-23-2007 16:54:25
Try the link below. Take the part number on your bearing and punch it in the search field. Select the bearing manufacturer you want and check out. They have consistently been 5-25% cheaper than my local bearing house and that includes shipping to my door.
El Toro
01-23-2007 13:28:53
Try baileynet.com at 1-800-800-1810. Hal
AB
01-22-2007 20:02:47
Bearing Distributors Inc. 888-423-4872. They have parts houses all over the US. I'd give them a call with your bearing part numbers and see how they compare. Let us know where you find them the cheapest at.
Jeff Oliver
01-22-2007 19:47:35
not sure where you are located but we use a local bearing shop that can usually get us most anything we need and at a better price than dealers. You can give them a call and see and if they cna help you they will probably ship.
Reelfoot Bearing Union City,Tn 38261 731-886-1111 Ask for Janna or TJ
