Light Wire
1755
02-19-2007 15:09:19
I was wandering a while back the lights quit on our 1755 and I opend the dash up and I had a mouse nest in there I gess I should not have left the weed seed piled up on the brush hog It had a hat full of it in there but they chewed up the wire from the key to the fuse I splised it and it quit agian (did not get all the roten wire I gess) I put a new wire in there this time I couldent find a 12ga wire I put a 14ga in there and after I put it back together I was wandering if it will be enough it has the 3 fender lights and the ones in the grill all apear to be origonal Just wandering if I should put a biger wire in there Thanks Thomas
Moishe
02-21-2007 16:56:56
 Re: Light Wire in reply to 1755, 02-19-2007 15:09:19
I would bet a 14 ga. is all you need. Remember that the wires generally are quite short under that dash area so when you have a larger power requirement there is less of a problem when the run is short. From my memory (which tends to get short lately!) most of the Oliver wiring was no larger that 14 ga. for the lights.
klf
02-20-2007 13:04:28
I don't know what the size of that wire was when that tractor was new, but I would use at least a 12 gauge wire. I tend to use bigger wire than required.
1755
02-20-2007 18:27:45
 Re: Light Wire in reply to klf, 02-20-2007 13:04:28
That is what I was thinking But I was hoping some one would say that 14ga is what the factory used thanks
klf
02-21-2007 14:00:13
 Re: Light Wire in reply to 1755, 02-20-2007 18:27:45
If you have the old wire, compare it to what you have.
1755
02-21-2007 18:42:36
 Re: Light Wire in reply to klf, 02-21-2007 14:00:13
I never took it out of the harnes I did not want to cut it up I will probly find some 12 ga wire the right color and put it in there but I am going to wate until it warms up it was 30 or 40 out there beside the shed and parked in an 18in snow drift to boot
B. Livingston
02-20-2007 12:59:42
To be on the safe side, I would install the heavier wire. I used to restore older autos and build/wire street rods. I can tell you from experience the lighter gauge wire will turn into a nightmare after a while. Change it out and you will sleep better.
