Steel vs. copper fuel lines
AB
03-15-2007 18:11:57
Those steel diesel fuel line assemblies (drip) -(the small ones) give me fits leaking all the time at the fittings/tees. A mechanic told me that replacing with copper would be a fix as copper seals better at the fittings. However, I've also heard that copper tubing has no place on a tractor as it will break down over time. With fuel prices so high and new paint a coming, I'm trying to eliminate all leaks. What do you guys think?
IanC
03-16-2007 18:27:31
 Re: Steel vs. copper fuel lines in reply to AB, 03-15-2007 18:11:57
I don't KNOW this is a fact but I would assume there are different alloys of copper tubing for different aplications. Some would be more vibration resistant, or more tolerant to the fluids flowing through them. Copper was probably frowned on in the past as the old fuels contained sulfur compounds (especially diesel) which attack copper.
dad's88
03-15-2007 19:26:34
The last new ones I ordered for my SUPER 88 10-20 years ago from White were copper.
J Schwiebert
03-15-2007 18:28:17
I had a set of lines in my hands a couple of years ago and they were copper. I would also guess you know the correct way on how they are placed on the tractor. You price a set and you want to set down. I would make two wooden blocks and use the wooden blocks for a "die" so to speak so the all look like they should when you bend them. J.
AB
03-16-2007 21:33:42
 Re: Steel vs. copper fuel lines in reply to J Schwiebert, 03-15-2007 18:28:17
Thanks to all. I think I will make my own out of copper.
