70 steering problems
530puller
03-30-2007 17:51:11
hi I have a 1936 Oliver Hart Parr with steering problems. I opened up the steering box and there was a bearing out on the end of steering wheel shaft near the worm gear. Where can i get this bearing? Are there better ways of fixing it?
JDen
04-05-2007 06:33:31
 Re: 70 steering problems in reply to 530puller, 03-30-2007 17:51:11
I just fixed that problem on my 1948 Oliver 70. If I can remeber right the number on it was a Timkin 16. I got one of mine from Welters Farm Supply in Verona, MO. There number is 417-498-6496. I'm not sure if they have anymore but you can try. There were 2 other places that I called that had them as well.
Mettler Impl. in Menno, SD 605-387-2323 and
Henkins Eq. in Chadron, NE 308-432-5593.
Hope this helps... GOOD LUCK on your project!
JDen
rrlund
03-31-2007 14:02:43
Never had one of those apart,but aren't they just a Timken taper bearing? If so there should be a number on it. Should be available from an auto parts store. Only other solution would be a box from a doner tractor in the boneyard.
