77 vs. 88
310
04-05-2007 12:03:11
Is there a easy way to tell the too apart if the ID tag is missing. Also will a 77 tub bolt to a 88 rearend? Thanks for any info.
Eric Bloom
04-09-2007 14:06:38
 Re: 77 vs. 88 in reply to 310, 04-05-2007 12:03:11
77 has 2 1/2" axles 88 has 2 3/4" axles
tub,rearend, grill, hood, and dash are wider on a 88 compared to a 77. but drawbar and such have same mounting dimensions i believe.
Wingate
04-06-2007 18:29:17
I believe the 88 has larger axles. Some one on here should know the size.
WARWAGON
04-05-2007 13:57:39
THE REAREND COVER ON THE 77 HAS JUST A LITTLE HUMP IN IT THE 88 HAS ONE COUPLE OF INCHES TALL
rrlund
04-05-2007 13:04:29
The overall height is one way. The 88 has a higher hood. If you look at the side of the grill,down at the bottom rear of it,there is a lip where it curves under about two inches above the frame on the 88. That's the quickest way for me to tell if I see one on TV or something.
