4-180 air in hyd
Adam Suess
05-06-2007 12:32:30
I am getting air in the hyd on my 4-180 and can not seem to track down the sorce. I've changed every hose and seal on the suction side including the filter seals as well as the oil cooler hoses. It mostly occurs when the oil is hot and will suck air when stoped just idleing or being used. The oil gets rather hot so I did add another oil cooler. It works fine other wise. there are leaks any where in the hyd system. Could the pump it self cause this?
