880 Power Traction Hitch
1755
05-23-2007 20:22:13
I got a new to me Oliver 880 the guy I got it from repanted it and then could not keep it. It needed a few Power traction hitch parts I thought how hard could those be to find I have called several places and the responce ranges from what is a power traction hitch to just sold a set last month. all I have to go by is the sails litercher and it calls what I need both lower lift links (the quick hitch part) and I also need the toplink I was told the lift links are diferant that there is a right and left I think I can make a toplink but I am not fermilur at all with the lower lift links or the hole hitch for that mater I was wanting to buy a set or barow a set to make my own I posted a few pics one in parts and pieces and one of the hole tractor in the regular photo page Thanks Thomas
Moody Richardson
06-01-2007 21:21:57
 Re: 880 Power Traction Hitch in reply to 1755, 05-23-2007 20:22:13
My dad and I bought a new 1963 Oliver "770" with the Power Traction Hitch. That hitch was a big improvement over the previous Hydraul Hitch. I especially appreciated the drawbar that could be raised up to move a very large load. When properly set with a semi-mounted plow this was a plowing machine. This plow was made for this hitch.(Important Note) The left lift link must have 4 - 5 inches of thread visable before the plow will ever plow level, then adjust the right side accordingly. Yes that Power Traction Hitch is worth repairing correctly. It was a good system in it's day and was a cheaper alternative by Oliver compared to the '1600' Oliver.
Earl Ohl
05-25-2007 16:52:35
Try Farmersville Equipment in Farmersville, Pa. 1-717-354-2150. If Tom doesn't have it, he can usually get it.
1755
05-29-2007 14:55:47
 Re: 880 Power Traction Hitch in reply to Earl Ohl, 05-25-2007 16:52:35
that was the one that was sugjested but I could not find there number Thanks
Iowa 1650
05-23-2007 21:15:30
Tom,
Try either of these places -
O"Brien County Implement
Sheldon IA Ask for Tom in parts.
Farmersville PA
Sorry I don"t have phone numbers. Both places helped me with mine. If your lift arms are just bent take them to a machine shop and have them make you new ones. I did that and they were about $30 a piece cheaper.
1755
05-24-2007 18:45:03
 Re: 880 Power Traction Hitch in reply to Iowa 1650, 05-23-2007 21:15:30
I forgot about O"Brien County Implement but one of my dealers that I called called several places and I am not shere who all he called but there was one in PA I found O"Brien's number but Farmersville Equipment was not on the agco dealer lokator are they not a actual agco dealer I will try O"Brien's tomorow Thanks Thomas
