Cockshutt 1755
560farm
05-25-2007 00:23:00
I am getting ready to restore the '73 1755 and wanted to make sure I have the correct white paint for the wheels and weights. Was it Bossline White like the White combines or another shade? I do believe it is the same white used on the '73 model year MM G955/1355 tractors. I know it was Sumac Red also called Combine Red like the White combines and some of the implements used. The tractor still has the original red and white paint on it, so I could always take parts to the paint store.
Thanks for the help,
Brad
El Toro
05-25-2007 03:22:31
 Re: Cockshutt 1755 in reply to 560farm, 05-25-2007 00:23:00
Here are some PPG's paint codes for Oliver Tractors. Hal
Clover White-8229 & 8805, Oliver Green-45132, 40249, 40812, MM Red-72263 &70385
PS: Here's a web site on MM tractors and the Sumac Red was mentioned.
http://jetstar.minneapolis-moline.com/paint.html
P Heisey-Harleysville,PA
05-25-2007 01:14:54
Brad,
My info. indicates that it should be CLOVER WHITE, same as used on the OLIVER 1755.
Hopefully, another responder can confirm or correct this.
Phil Heisey 215-256-8651 FAX 215-256-1203
