199 oliver diesel 6 cylinder
2oliver?
06-12-2007 07:23:59
I have found a 199 diesel power unit with a water pump hooked to it is this a good motor to maybe but in a 1600 oliver ? What kind of power will it have and is there a way to get more power out of it ?
good6742
06-12-2007 11:21:01
 Re: 199 oliver diesel 6 cylinder in reply to 2oliver?, 06-12-2007 07:23:59
I would be interested in buying the power unit as it is if you wanted to sell it. I have a 177 power unit now and I think they are kind of neat. Thanks,
Lance
MikeOwi
06-12-2007 13:40:03
 Re: 199 oliver diesel 6 cylinder in reply to good6742, 06-12-2007 11:21:01
I would be interested in the water pump if you could email the specs. I also need to know the size of the intake and exhaust where the fittings screw on. Also it would be helpful to know where you are located.
Larry from md
06-12-2007 09:20:11
A 199 should have more power than a 1600.
