Oliver Super 77 Diesel wheel color?
960
06-16-2007 03:55:03
What color are the wheels on an Oliver Super 77 Diesel? Were they all the same or depends on serial no.?
960
06-17-2007 08:46:09
 Re: Oliver Super 77 Diesel wheel color? in reply to 960, 06-16-2007 03:55:03
Thanks for your help. The serial is 14866-702. The tractor chassis and hood has original paint with the wheels having peeling red on top of the probably original green.
bradk
06-17-2007 11:36:31
 Re: Oliver Super 77 Diesel wheel color? in reply to 960, 06-17-2007 08:46:09
1955 model.Green
ollie770
06-16-2007 08:11:00
For the Super Series of Olivers, the tractors had green wheels from 1954-1956. In 1957, Oliver switched back to red wheels because of too many complaints about the green wheels. They also made some other changes to the Supers in 1957. So 1957-1958 have red wheels.
bradk
06-16-2007 07:35:57
Like Mike said,you need to know the year via the ser. number.I have a '55 super 77 and the wheels are green.
Post the ser. number and we'll find out. ~brad
OlMax
06-16-2007 07:35:46
My Super 77 Diesel , mine is a 1956 model, has red wheels. I think they followed the regular red color from the 77"s and 88"s until they changed to all green with the later models. Mine has power shift rails on the rear and red cast centers on the front with green rims. The rear rims are aluminum color but the center cast is red. We bought it used when it was only 2 years old, never repainted.
OlMax
06-16-2007 13:05:08
 Re: Oliver Super 77 Diesel wheel color? in reply to OlMax, 06-16-2007 07:35:46
More info, I checked my tractor, Serial No. 28-133-702. Spec. No. 17-0030. I think that makes it a 1955 model. Maybe the power adjust wheels made a difference as they were not very popular because of the extra cost I would imagine. However I've not seen very many 77's and 88's with the power adjusted wheels. My suggestion is do some scraping down to bare metal and see what you find. Remove cast wheel from hub and see what you find for color in a protected area like that. Good Luck
Mike Koebel
06-16-2007 06:49:46
If they were like the Super 88s, they were green until I believe 1958. At any rate you will need to know the year your tractor was produced to be accurate.
Mike in Illinois
El Toro
06-16-2007 04:34:17
I think they were red. Hal
