2255 Oil Filter Problem
2255
07-08-2007 07:29:56
Changed the engine oil filters on a 2255 and when I started the engine and ran it for a bit, oil started leaking out around the back filter gasket. Tighted the filter but it didn't stop. So I put a new back filter on and same thing happened. Any ideas what may be wrong?
KBS
07-08-2007 18:50:37
 Re: 2255 Oil Filter Problem in reply to 2255, 07-08-2007 07:29:56
Check the filter you took off sometimes the filter gasket stays on the filter housing,so then you have (2) gaskets on (1) filter,
TERRY FOSS
07-08-2007 07:37:07
CHECK THE THREADED CENTER WERE THE FILTER SCREWS ON ,SOMETIMES THEY WILL UN SCREW A TURN OR TWO WHEN TAKING THE OLD FILTER OFF.I HAD IT HAPPEN ON MY G 1355,SAME FILTER BASE
