Question for J Schwiebert
770
08-12-2007 09:48:50
How hard to put a power booster on a 770 that never had one??? Any "special techniques" that would be helpful? thanks...1966
J Schwiebert
08-13-2007 02:44:39
 Re: Question for J Schwiebert in reply to 770, 08-12-2007 09:48:50
Do you have a complete unit out of another 770? You must be going pulling? It is not rocket science to put one in.
770
08-13-2007 05:37:08
 Re: Question for J Schwiebert in reply to J Schwiebert, 08-13-2007 02:44:39
well... wasn't sure if you had to move the engine of it's mounts, and I have heard of alignment issues, but I've since decided against it. I'll keep mine true to the build card. just turned 2400 hrs. I have others to play with....
J Schwiebert
08-13-2007 08:08:13
 Re: Question for J Schwiebert in reply to 770, 08-13-2007 05:37:08
You guys that say: " I ve heard"!. Yes the engine has to come out to install one. I started with the Power Booster program in 1960. I don't recall any alignment issues. However there is a tool to align the housing. A dial indicator would do in a pinch.
D13
08-14-2007 06:55:13
 Re: Question for J Schwiebert in reply to J Schwiebert, 08-13-2007 08:08:13
Assuming you have the complete unit, what else has to change? Input shaft to the trans? And is it the same set up on 880?
J Schwiebert
08-15-2007 19:45:44
 Re: Question for J Schwiebert in reply to D13, 08-14-2007 06:55:13
Well your leaving yourself open to a lot of discussion here. First of all the unit from the 880,is it for a spur gear or a helical gear transmission. Both shafts need to change from non power booster to power booster. Send me a phone number O. K.
