Motor Generator
60 Fan
08-29-2007 17:36:26
I'm sure it has been discussed before but once again. How do you go about motoring a 6 volt positive ground three brush generator? What should I expect for speed? Thanks.
J Schwiebert
08-29-2007 18:08:27
 Re: Motor Generator in reply to 60 Fan, 08-29-2007 17:36:26
You need 3 jumper wires. Hook one of the battery cables to the Armature terminal, the other one to the generator case. It should spin at a moderate RPM. Hook the thirs cable to the field terminal and then ground the other end. The generator should slow down and motor slowly. If not there is a problem. I will try to send you an e-mail in the morning. I have some generator troubleshooting information that I did for an article in the HPOCA magazine. More questions> J.
