Magneto Question on a Cletrac....HG
keith stromberg
09-26-2007 07:48:43
Tryed to find a little more info for the Cletrac HG I have and could not locate any serial number plates. Also the Magneto has a IH (international Symbol) on it with a L above it. Did not find any numbers on it either. With this info can anyone help ID this magneto? Also is there any way to ID the engine? Its 4 cylinder with a flat head on it, I did find a casting number on the top of the block. Would that help?
TIA!!!!
Keith
Larry from Maryland
09-26-2007 09:37:39
 Re: Magneto Question on a Cletrac....HG in reply to keith stromberg, 09-26-2007 07:48:43
Yes post any casting numbers you find. If its a herk IX? it should have numbers cast on the right side just above the oil pan.
old
09-26-2007 08:54:08
Engine should be a hercules IXB or one of the other IX series engines. Flay head and have the mag on the right side of the engine. Mag sounds like its one off an old farmall H which if I rememebr right would be a J-4 mag. The mag if correct should be a model X, but there are a good many other mags that will bolt right up and work just fine on those engines.
