880 Front Wheel Berings ??
1755
11-12-2007 19:26:41
I took the Big cast iron hubs off the 880 to check the bearings and the one side had no seal and old tar like grease like it has never been changed and no seal and a extra washer behind the nut that is not in the book the other side had a thick oil in there thicker than 80/90 and the back bering was bad and the seal is runed so I have to put one bering in each side and both seals and gaskets but what kind of grease is supost to be in there the book said xxpound of lithium grease is that regular wheal bering grease or something els what is the best stuff to put in there the guy at the parts plase said there is supost to be oil in there thanks Thomas
1755
11-15-2007 18:59:52
 Re: 880 Front Wheel Berings ?? in reply to 1755, 11-12-2007 19:26:41
I alredy have some regular wheel bering greese it is supost to be water resistent I think I have never Torqed a nut on the wheel berings but I have had to go back in to re titen after working on the 1755 but have never had any problems with the rest I always titen to where I think it should be then titen until the key will go in
Dean Barker
11-14-2007 19:52:34
I've been using moly ep grease instead of wheel bearing grease for over 40 years now. Prevents any rusting when tractor sits for long periods between use. Also, tapered bearings that do not run fast as in this case can be run really tight.
Torque the adjusting nut to about 20 lb-ft, yes 20 pound-feet.
ollie770
11-12-2007 19:55:13
At one time Oliver had you use gear oil in there (hence the little pipe plug on the cast center) but later they changed to recommending just packing your wheel bearing with just standard wheel bearing grease. Clean everything up really good and then replace your bearings and races, and wheel seals. Then pack and coat everything with new grease. That washer was probably added by someone, I dont think Oliver used a washer between the nut and bearing but I know some vehicles have them so it is probably your decision just as long as the wheel bearing is adjusted properly.
ollie770
11-12-2007 19:50:23
1755
11-13-2007 17:18:32
 Re: 880 Front Wheel Berings ?? in reply to ollie770, 11-12-2007 19:50:23
Thanks that sounds like a normal deal then I will have to see about that washer if it needs to be in there to take up space or not I figured that the one on the other side got lost it lookes like it all came apart on some one the nut is all bugerd up and the hub cap is welded up regular wheel bering grease is a mess but it wont leak out onse I get it in there one less leakey thing would be a plus thanks Thomas
