clutch shaft coupler
77ollie
12-10-2007 05:05:46
Trying to remove belt pulley mechanism, loosened coupler on clutch shaft, removed input shaft set screw, no luck sliding coupler onto clutch shaft. First time working on Oliver. HELP!!
pllr
12-10-2007 13:52:42
 Re: clutch shaft coupler in reply to 77ollie, 12-10-2007 05:05:46
p.b.blaster and patience, or heat
J Schwiebert
12-10-2007 05:37:47
Did you take the long PTO shaft out? Have you folded the dash over? There are 7 bolts that hold the pulley on. One of those is a 1/2 inch bolt. If you have not done so at least buy yourself an I & T shop manual. Yoy will also need to plug off a few holes once the pulley is removed. Do you have the KS 618(I think) sleeve to put on once the pulley is off?
77ollie
12-10-2007 05:48:37
 Re: clutch shaft coupler in reply to J Schwiebert, 12-10-2007 05:37:47
Yes, I have removed PTO, removed instrument panel, & coupler is froze on shaft. I thought some one might have suugestion how to free up. I have the complete Oliver manual (several hundred pages). Thanks for your reply
