Waukesha Spec's - J Schweibert
A.P.
12-20-2007 02:55:40
I ran across a Waukesha 195GK spec. #195GK 16-G and serial number 988839. Can anyone tell me if it uses a large rod journal crank and what the compression ratio should be? It has a 4 1/8" bore x 4" stroke (320 cubic inches) and has what I would classify as an early block; freeze plugs on the right side and the rectangular panel on the left.
Thank you
BM
12-20-2007 12:33:44
 Re: Waukesha Spec's - J Schweibert in reply to A.P., 12-20-2007 02:55:40
Does it have a rpm rating on the tag?
A.P.
12-20-2007 17:03:54
 Re: Waukesha Spec's - J Schweibert in reply to BM, 12-20-2007 12:33:44
1800
J Schwiebert
12-20-2007 05:40:57
Without looking, I can think of 3 and maybe four different cranks used in 195 engines. I sent you an e-mail. I don't know if I have a 195 parts book. Used to have a 195 shop manual till the basement flooded. I will look between now and the weekend. J.
A.P.
12-20-2007 05:53:48
 Re: Waukesha Spec's - J Schweibert in reply to J Schwiebert, 12-20-2007 05:40:57
Please resend the message through the YTMag response system but include your email address in the text of the message. it did not come through on your earlier response.
Thank you
