Bolens tractors
PAUL IN CALIF.
01-15-2002 19:57:09
Where can I get parts for them? I was told there is a place on the east coast called the Bolen's boneyard, but cant find it anywhere. thanks
walter richardson
04-14-2003 13:03:55
 Re: Bolens tractors in reply to PAUL IN CALIF., 01-15-2002 19:57:09
i need a clutch for a bolen g 294 4 wheel drive
Gary Birchler
07-16-2002 06:02:16
I have a Bolens G174 3 cylinder desiel. The hydraulic lift won't raise a load anymore. When it is not hooked up to anything it will rise but you can easily push it back down even with the tractor running. Does anyone have any ideas as what is wrong and what I need to do to fix it?
Thanks
Jenny
02-15-2005 18:28:53
 Re: Re: Bolens tractors in reply to Gary Birchler, 07-16-2002 06:02:16
Take the cover off of the transmission and replace the o- ring on the plunger.
scott
11-12-2002 15:14:54
have bolens g274 a bigger model than you have. looking for the front diff and drive shift. to complete 4wd for this model. just rebuilt motor and would like to have 4wd. a good model does what it has to.
Wayne Herring
06-13-2002 21:35:02
Question:
Did Bolen buy out Porter-Cable lawn tractors some years ago?
I have a porter-cable and is in good shape but i'm looking for parts for the mower.
thanks wayne
Eugene Steffanus
06-23-2002 04:53:57
 Re: Re: Bolens tractors in reply to Wayne Herring, 06-13-2002 21:35:02
Do you have a coil kohler#230075
K-161
Spec#28118E
Bob
06-09-2002 08:22:46
Looking for side discharge parts for rear bagger. Bolens St 120 Suburban.
Geoff Hopps
06-05-2002 19:59:48
I have a Bolens type 35AA01, ser #R614 tractor. It is the articulating type and am in the restoration process. Does anyone know the paint codes or where I could get them? It appears to be light green with pale yellow wheels and seat. Thanks.
1961 Bolens tractor
03-28-2002 10:58:31
My father has a 1961 Bolens lawn tractor and desperately needs a part for it. The tractor needs a hydro assembly part. The model # is 197-03
Serial # - 8361
Transmission # - 16145
Part # - 1719864
If there isn't such a part, he would settle for a hydrostat pump.
Please contact Charles at (989)539-1906.
joe
02-11-2002 08:48:42
I have a Bolens with a 16 horse Tecumseh it runs but smokes. Hydro barley pulls. would make a good parts tractor. Make an offer. 918-429-3887
Bill
01-21-2002 03:22:18
How old a Bolens? If your talking 10-15 years including the 4x4 Iseki's try :
www..exmarkdealer.com/pipersville/lines.htm
That is the web site for Pipersville Garden Center. I'm from the Troy NY area. Some friends/former Gardenway employees recommended I go here for parts for my '91 4x4 Bolens/Iseki. They gave this dealer very high marks on knowledge/service. First time I called they knew exactly what I was talking about, thought they had it in stock, they didn't but they ordered it somewhere & had it to my door in a week. I was impressed. Last I talked to them, due to the pricy parts for the Iseki's they were going to start a Bolens bone yard. Hope this helps....
STEWART LAYTON
03-09-2002 07:45:55
 Re: Re: Bolens tractors in reply to Bill, 01-21-2002 03:22:18
I can purchase an 87 Bolens, diesel, 4 wheel drive 17 HP w/ front end loader, 3 speed PTO, bush hog, box blade, and 7 other implements for $4500, ag tires in good shape....Seems straight and in good working order...Front end loader needs gaskets - has slow pressure loss.
What am I getting in to with this please. Know nothing about the Bolens. Seems right for my applications.
greg ducker
06-05-2002 04:39:33
 Re: Re: Re: Bolens tractors in reply to STEWART LAYTON, 03-09-2002 07:45:55
I am looking for the tractor front universal joint inside the 4-wheel drive unit for the Bolens Iskie. Any help you can give would be appriciated.
