Barber greene pictures posted X2
Dave
01-23-2002 02:16:56
Barber Greene pictures posted in the tractor gallery, still hunting any information possible. All l have been able to find out is it might be a 'Barber Greene runabout ditcher'. Any extra info would be fantastic.
Jeremy Smith
09-27-2006 23:10:09
 Re: Barber greene pictures posted X2 in reply to Dave, 01-23-2002 02:16:56
If you still have this machine. It is A Barber Greene ditcher, minus the ditcher like mine I have seen a picture of a later model with the ditcher and it is a cool looking machine. My tractor is one of the earliest versions before they put fenders on them. I believe it is a 1948 model. its in pretty rough shape, but I do have it running and such and am in the process of fixing all the small stuff. brakes, hand brakes, shift linkage ect. and removing all the mud wasp nests from all the lines and tubes and vents. Any ways I pretty sure that you barber greene is powered by a U6 IH engine The radiator is copper core/cast top and bottom tanks and cast side supports. The tractor has a C channel frame. The engine powers a 2 speed fuller gear box, then into a welded gear box with a pto on top of it the pto should have a chain sprocket on it. that gear box is then connected to a tractor trans. and rear end. I belive the trans and rear end are the same as a farmall M or super m or mta. IF YOU STILL HAVE THIS TRACTOR, I AM WILLING TO PAY FOR ROLES OF FILM AND DEVELOPING AND POSTAGE AND FOR YOUR TIME TO TAKE PICTURES OF IT INSIDE/OUT, UNDER SIDE TOP SIDE CLOSE UPS BACK UPS EVERY ANGLE. IF YOU GET THIS PLEASE EMAIL ME!! ANY INFO IS GOOD INFO. THank you Jeremy Smith
