Unimog
jack
01-28-2002 04:57:48
anyone use a unimog on their farm, If you do, how do you use it?
Unimog
01-28-2002 19:16:06
 Re: Unimog in reply to jack, 01-28-2002 04:57:48
I use a 406 model to tedd hay, chip wood with a
Valby on the 3-pt, pull hay trailer and use a
3-pt cement mixer. Great machine for many uses.
Mine has the 3-way dump body which is handy in
tight places. The Mercedes diesel is cheap to run
and the 20 speed gives you all kinds of control.
When lunch time comes you can shoot down the road
at 45 mph and it the diner. Love it.
Unimog
jack
01-29-2002 04:35:52
 Re: Re: Unimog in reply to Unimog, 01-28-2002 19:16:06
would they have enought power for a small no till drill, say 10 to 15 ft. also how sharp turners are they. Just curious, what part of the country are you located.
Bernhard
01-28-2002 08:53:22
A Unimog is a multi-purpoose-tractor, it is designed to do every Job You want to, as there is:Farming, Logging, Hauling (80km/h) etc. and very much more.
Bernhard, Derichsweiler, Germany
jack
01-29-2002 04:34:10
 Re: Re: Unimog in reply to Bernhard, 01-28-2002 08:53:22
what models of unimog are the best for agriculture use? seems like numerous models out there>
Unimog
01-29-2002 20:06:04
 Re: Re: Re: Unimog in reply to jack, 01-29-2002 04:34:10
The best all around Mog for farm use is the 406
or U900. It has 84hp, 20spd, airlock axles and is
shorter then a standard 8' pickup truck. Most of
the other models are non-ag units more geared to
military and commercial uses. It turns almost as
short as a tractor and with 20 speeds forward and
8 in reverse it can run about implement. If you
need a source for Unimogs I can give you the name
of someone you can get any type from.
Unimog
jack
01-30-2002 04:29:43
 Re: Re: Re: Re: Unimog in reply to Unimog, 01-29-2002 20:06:04
who is your source? also does yours have a 3pt or not?
Unimog
01-30-2002 09:45:32
 Re: Re: Re: Re: Re: Unimog in reply to jack, 01-30-2002 04:29:43
Yep, I have a Cat II 3-pt. You can have a front
mount 3-pt as well and a front PTO and hydraulics.
Chris Elliott sells all types of Unimogs and can
have one speced to meet your needs. He is located
in Rhode Island but ships all over the country.
He has 2 going to Montana and 1 to Florida this
week I believe. Here's his info:
Phone-401-333-3994
Cell--401-440-4984
Email-RImogs@aol.com
Web---Http://hometown.aol.com/RImogs/index.html
Unimog
jack
01-31-2002 04:23:12
 Re: Re: Re: Re: Re: Re: Unimog in reply to Unimog, 01-30-2002 09:45:32
would like to talk to you about your unimog on the phone sometime. Is it possible and what a good time if I can.
Unimog
01-31-2002 10:50:55
 Re: Re: Re: Re: Re: Re: Re: Unimog in reply to jack, 01-31-2002 04:23:12
Jack, you can email me direct and I'll give you
my number off list.
jack
01-31-2002 12:41:13
 Re: Re: Re: Re: Re: Re: Re: Re: Unimog in reply to Unimog, 01-31-2002 10:50:55
he is my email. if you want to send number:
Bernhard
01-29-2002 14:54:49
Hi Jack,
what a kind of farming do You want the Unimog for?
There are a lot of different HP-ranges. Starts with 34HP at the older ones, from appr. late 60' to early 70' up to 250HP to the newer ones.
If Unimog has a 406 it has 70 or 80 HP.
In Germany there are the most Unimogs in use for hauling at hauling-contractors, at communal and Highway Services and at the Army. Some of the for Farming, but not so much, most at agricultural or forestry-contractors. The Brand "Werner" which is a manufacturer of forestry-winches is building an articulated-tractor, based on the Unimog. Best You can do, is ask Mercedes-Benz, there are a lot of people who can help You. You can also contact the "Hohenheim University" (Universitaet Hohenheim) which has a Test area for Tractors. If You don't find something about them, post it here, or send me a mail. I gonna try to help You.
frank
01-30-2002 05:06:46
 Re: Re: Re: Re: Unimog in reply to Bernhard, 01-29-2002 14:54:49
do you have a web address for werner. did search and noth came up.
Bernhard
02-01-2002 13:56:06
 Re: Re: Re: Re: Re: Unimog in reply to frank, 01-30-2002 05:06:46
Hi Frank!
You have to serach for "Werner Seilwinden" or "Werner Unitrack", may You have more success than I had, maybe Werner doesn't exist no more.
They where located in Trier in Germany.
Bernhard
