Avery A with Hercules engine
a manifold question ???
Alberta Mike
02-04-2002 16:00:59
The exhaust pipe stack that attatches to the manifold on an Avery A (Hercules IXB3 engine) seems to be 1/1/2" iron pipe size (1 7/8" OD). Does anyone know if this pipe is threaded into the manifold? This one of mine has been welded around the join location and the pipe is in pretty rough shape (manifold is fine), however if I knew that it was originally threaded in, I'd cut it off and clean out those threads and put in a new threaded pipe before putting this all back on the engine. Let me know please if you know how the pipe joins the manifold.
Esev
02-04-2002 18:37:48
 Re: Avery A with Hercules engine - a manifold question ??? in reply to Alberta Mike, 02-04-2002 16:00:59
The few that I have worked on did not have iron pipe threads. They were a forced fit piece of exhaust pipe. The later A's had a hold down bolt for holding a muffler I believe.
