Satoh 650G electrical problem
Bill H
02-15-2002 21:11:34
My Satoh will start three or four times and run great and then not even try to turn over(it may click once). Has rebuilt starter, new ignition and battery. Any suggestions? Does it have a negative or positive ground? A friend installed the battery and he has it on a negative ground.
Thanks.
ROB
02-17-2002 07:25:23
 Re: Satoh 650G electrical problem in reply to Bill H, 02-15-2002 21:11:34
have to agree with the other guy. just the switch or a bad connection.
but if all else fails.....
www.antiquetractorsonline.com
free message boards has a satoh s650g board.
good place for lots of info & parts....
just read down threw the post headings at the bottom you will find some good cross reference #'s for tune ups and filters.
good luck
D.M.Cosper
02-16-2002 20:08:38
Bill,
I doubt it is a positive ground personally.
If it was hooked up backerds, thats a southern term, it would blow the chargeing system or the battery.
Take a circuit testor and see if the ignition switch works when it "clicks" when you try to start it.
Check the contacts everywhere, where wires terminate into another part of the circuit. It might be a short(open actually) somewhere.
Check to see if the alternator is chargeing, it should be putting out 13.5 volts, + or - a little, at full engine RPM.
Hope this helps,
D.M.Cosper
