Silver King Battery
Dan J
03-23-2002 05:07:57
My Silver King 42 is going to need a battery this spring. The standard 6V battery is too tall to fit. What are you guys using for a battery for these tractors? thanks, Dan
Galen Ishman
03-23-2002 05:28:07
 Re: Silver King Battery in reply to Dan J, 03-23-2002 05:07:57
New Castle Battery in Pa. makes a battery I found that works perfectly.It is a 6 volt type "19L"
It is the same battery used in early 6 volt Volkswagon Beetles. There is so little clearance between the Gas tank and frame that it is the only battery that will work unless you convert it to 12volt side terminals.
Jerry
05-13-2002 18:23:04
 Re: Re: Silver King Battery in reply to Galen Ishman, 03-23-2002 05:28:07
Wonch makes a low profile 6 volt bat that fits in the silver king check with your wonch deal and mabe sears i heard you can get low profile frome them
Thanks Galen
03-23-2002 07:40:13
Thanks Galen, I did not want to convert to 12V as the tractor is in show condition. I was looking at the batterys specially made for old cars at $150.00 per. I'm too frugal (ok cheap)to spend that if I don't have to. You saved me a lot of trouble (and money). Aint this forum great? Dan J
