Satoh Beaver S-370 transmission fluid
Mark C.
04-20-2002 13:44:12
Would like to know what type fluid is specified to put in the transmission. Is regular GL-5 SAE 80/90 gear oil OK or do I need the combination hydraulic/transmission oil?
Thanks.
Mark C.
David L. Edwards
10-27-2002 18:11:02
 Re: Satoh Beaver S-370 transmission fluid in reply to Mark C., 04-20-2002 13:44:12
I need a key switch, the one I have doesn't work on the glow plug side of the switch.
GEORGE BROWN
07-10-2002 05:26:19
Mark,
I know what the book says,
but if you read futher in the hydraulic section it says to use hydraulic\transmission oil,
on the tractor itself it says to use 80w90 gear oil, so there are a lot of conflicting specs.
I am a diesel Mechanic and heavy equipment,
and take my word for it a hydraulic pump will not pump gear oil.
Eugene
07-09-2002 21:01:52
I have a book with mine and it says below 20 deg use Shell Dentax 80 or Mobil fluid 423 and above 20 deg. use shell Dentax 90 or Mobilube C80
GEORGE BROWN
07-09-2002 08:49:36
Mark;
I have the book on my satoh beaver and you must use hydraulic\transmission oil because the hydraulic pump uses that oil,
George
