Wain Roy Backhoe
KC
05-08-2002 12:16:50
Hi,
Today I found a Wain Roy Backhoe cira 65-68 for sale. It has a diesel engine that runs real well. All things seem to work real well with the exception of the transmission. The guy has the tranny in a box. It needs bearings and two gears that I can see. the price is real low ($1500). My question is can I but the parts to rebuild the tranny? I could really use this hoe and I can do most and mechanical repair.
Danny jr
05-23-2006 17:32:08
 Re: Wain Roy Backhoe in reply to KC, 05-08-2002 12:16:50
Hey
If your not interested in that machine and it is a 450 series i would be interested in it
Thanks Danny
Joer189
12-24-2005 15:20:43
I also am considering purchasing a Wain - Roy backhoe. Its a model 3500D, Serial # 1235, does anyone know how old this baby is?
Can you still get parts?
Does this have the type of diesel that is "basically a converted gas engine" mentioned in another post? My main use is to clear my driveway afetr heavy snows so this is important to me?
Any help would be greatly appreciated.
Thanks
Merry Christmas
Joe
doozer
03-28-2005 17:27:28
Holy Cow!! I thought I was the only one one the planet with a Wain Roy Loader/backhoe!!! I use it for digging out stumps here on the "farm", moving firewood, boulders, etc. I have no idea what year it is, and so far no one has had any info. Any help as to where to get parts, manuals etc would be greatly appreciated!!! It"s a WainRoy Loader/ backhoe,
Model 450, serial # 1112.
Thanks, Joe
Danny jr
05-23-2006 17:25:58
 Re: Wain Roy Backhoe in reply to doozer, 03-28-2005 17:27:28
Hello
I am looking for a rear end for a 1969 wain roy backhoe. Any help would be appreciated.
Danny
david allaes
05-17-2003 18:13:52
let me know how you did on the backhoe you were looking into.
Unimog
05-08-2002 20:09:18
KC, I have a 1966 Rustler model with a Ford 172
diesel. Great machine for it's time, but tough to
start in cold weather. It's basically a gas motor
converted to diesel. If yours is the same model,
220, it should have a Funk Revs-o-mat in front of
a 4-speed gearbox. Parts are still available from
most any good trans-supply shop. Wain-Roy used
many parts from old Ford truck stock. Bango rear
diff, front hubs, 4spd trans, front wheels, etc.
were some of the items used. These machines dig
great and were far ahead of anything else on the
market at the time.
Unimog
KC
05-09-2002 03:54:03
 Re: Re: Wain Roy Backhoe in reply to Unimog, 05-08-2002 20:09:18
Thanks Unimog,
I'm going back over today with my digital camera and snap a few shots. I will also check with a few tranny shops and see what I can find out. Could you tell me where to find the ID tags?
Regards, KC
Unimog
05-09-2002 07:51:22
 Re: Re: Re: Wain Roy Backhoe in reply to KC, 05-09-2002 03:54:03
The serial # on mine is on the side where the step
is, right, on a tag just under the lifting arm
mount. Does yours have the 2 trans as I mentioned
before?
Unimog
Gus
06-12-2002 13:34:09
 Re: Re: Re: Re: Wain Roy Backhoe in reply to Unimog, 05-09-2002 07:51:22
Hi I have a rustler too. Mine runs great also and starts ok here in NC winters I just need to know where to find either a rebuild kit or a new two stage pump for the hydraulics any help out there?
Ralph Laragione
02-09-2005 21:54:02
 Re: Re: Re: Re: Re: Wain Roy Backhoe in reply to Gus, 06-12-2002 13:34:09
Have wainroy rustler as well, 1963 model 4500 I believe and has 4 cyl. ford industrial engine.
Had to replace 2 stage pump, 2nd stage for power steering. I'm not shure what model and year of
of your machine and if they are the same but I had the pump apart and shafts for gears were held by bushings and not roller bearings which is not
as good.
Pump is made by cessna, And I tried to locate one
but they don't make it anymore.
Original pump is aluminum housing without roller
bearings.
I matched up pump with steel or cast iron housing
and rollerbearing by gallons per min. at a certain
rpm as indicated in manual for pump output.
Went to machine shop to search and matched flow.
Had to alter pump cover to fit new pump.
Tony Socci
08-10-2003 05:38:17
Need help on locating ring and pinion gear for 1966 wainroy 450. Has Funk transmission as mentioned in earlier post , not sure about the rear end, would it be Ford? Would actually prefer picking up entire rear axle assembly if available.
Any help/info would be much appreciated!
