Long 360- GEO help?
Bus Driver
05-14-2002 04:23:16
Removed the seat to replace it. Got lucky and found (at Northern) the vinyl/foam covering to go on my existing seat. But the main question is the "big nut" over the check valve. I can't find it! Thought I would clean the check valve while the seat was off. The only "big nut" under the seat on mine is more to the right side and it accesses the hydraulic control linkage. About a 24mm wrench fits it. Looks somewhat like the master cylinder fill cover on F600 trucks. Is the "big nut" over the check valve removed with allen wrench? One of those is center front and has not yet been removed.
