Bearing flanges for Long 1080 offset disc harrow
H. Elnathan Bro
06-19-2002 16:58:59
I am looking for flanges to fit W211PPB6 bearings used on Long model 1080 offset disc harrow. This flange has 5.5 inch bolt circle and the bearing is a little over 4 inches in diameter. The axle size is 1.5 inches. This is a heavy duty bearing and apparently Long is the only company to use a flange attachment. No bearing company that I have checked with has this flange. I'm hoping that some older dealership or an individual may have some available since Long has long been out of the disc business.
GEO
06-24-2002 20:20:57
 Re: bearing flanges for Long 1080 offset disc harrow in reply to H. Elnathan Brown, 06-19-2002 16:58:59
I am assuming you are looking for the two half flanges that hold the bearing and has four bolts to fasten it to the drop frames. Most any aftermarket tractor parts supply house can get or should have the 100MM flanges.
I used to keep them in stock by the dozens. Surely things haven't changed that much in the last 4 years.
Larry
06-21-2002 09:49:13
Long is still selling tractors.I would try Agri Supply 1-800-345-0169.
