New '47 Model V Avery project begins...
GaryP in Tennes
06-25-2002 11:52:06
Hello All,
I'm a tractor newby with a few questions. I just bought an old Avery Model V. I am wondering where I may find a set of rings, gaskets and a manifold for the Hercules ZXB2 engine. I also need to rebuild the Tilliston Carb or replace it with something compatable. Any suggestions will be helpful.
LarryE in Ky
06-25-2002 18:59:39
 Re: New '47 Model V Avery project begins... in reply to GaryP in Tennessee, 06-25-2002 11:52:06
Am on verge of buying a model V. Grew up on one, kicked myself many times for letting it get away. Maybe we can start a "support group". Will be doing much research from this point unless the sale falls through.
Stan
06-26-2002 14:09:24
 Re: Re: New '47 Model V Avery project begins... in reply to LarryE in Ky, 06-25-2002 18:59:39
I have a MM Avery V. Made by Moline after they bought BF Avery's backrupt company, according to what I've read. It's almost same as the red Avery V's, but yellow, and has a different front axle. It's for sale. Engine will run, but needs rebuilding. Smokes, etc. If you're interested, reply and we can talk by phone. I've got 2 other tractors and a payloader to restore, need money, room, and time.
doug lage
08-25-2005 15:10:55
 Re: Re: Re: New '47 Model V Avery project begins.. in reply to Stan, 06-26-2002 14:09:24
would like to see a photo & location??
Thanks
Jon
06-28-2002 12:00:35
 Re: Re: Re: New '47 Model V Avery project begins... in reply to Stan, 06-26-2002 14:09:24
Message for Stan: What Payloader do you have? I have an HY that I am looking for info on. Thanks. Jon
Stan
07-03-2002 07:31:01
 Re: Re: Re: Re: New '47 Model V Avery project begins... in reply to Jon, 06-28-2002 12:00:35
Sorry I'm so late getting back to you, I neglected to check this board for a few days. My Hough is a model HA. I found a parts book for it on E-bay. I check there occasionally for books. I think the HA is the smallest loader they built. It's 2-wheel drive (front). I'm in the middle of tearing down and rebuilding lots of things on it. I've got several other thing going too, so I'm afraid it's gonna be at least a year before I make substantial progress on the Hough. I haven't been able to find any web-site with info on the Hough, have you? BTW, I'm in north Alabama, near Huntsville. Good luck.
GaryP
06-26-2002 05:24:27
Well, here is something to remember, When removing the engine: You MUST remove the flywheel to reach the 2 motor mount bolts that are installed from inside the clutch housing....
Everything is going reasonably smooth though. I managed to get the last piston out of the block with the aid of a press. The cylinders actually cleaned up very well. Next: THE CARB.... Any help with finding parts will be appreciated. I need a gaket set & an intake/exhaust manifold.
Esev
06-27-2002 07:34:33
 Re: Re: Re: Re: Re: New '47 Model V Avery project begins... in reply to GaryP, 06-27-2002 04:40:24
Yes, I am always interested. Thank you. I would also appreciate it if you let me know if you come across an extra parts transmission, and or a PTO for one of these tractors. I am told the Massey Harris Pony also used the same transmission, and PTO. Take Care.
Mike
06-27-2002 17:28:12
 Re: Re: Re: Re: Re: Re: New '47 Model V Avery project begins... in reply to Esev, 06-27-2002 07:34:33
I have a good used manifold for a V and a complete motor for parts if you are interested. Yes, massey harris pony PTO does fit a V.
Mike
