Deutz 80-05 and D-65
John-New York
07-11-2002 19:08:30
Can someone tell me the years made of both models? Anyone own one of these that would like to help me with problems that arise during restoration? Thanks John
Ben Irving
09-18-2002 12:08:29
 Re: Deutz 80-05 and D-65 in reply to John-New York, 07-11-2002 19:08:30
Also I have the original workshop manuals supplied by Deutz (engine & transmission etc)back in 1974 that cover the D75 05/06, 80 05/06, 90 05/06, 100 05/06 and 130 06. Please contact me if you want any further info. While I am at it, I am at the moment restoring a Deutz D11(I think!). It has a Deutz F1L 612 engine. I am struggling to find a new or good secondhand cylinder/piston for it. Any one?
Gene
01-14-2003 18:14:30
 Re: Re: Deutz 80-05 and D-65 in reply to Ben Irving, 09-18-2002 12:08:29
I have recently purchase a 80 05A, the 4 wheel drive version.
I'm hoping to find parts for the front axle, most importantly, the sun gear parts.
any information on this would be appreciated.
Gene
Ben Irving
09-18-2002 11:45:01
I've restored several Deutz tractors, including an 80 06, 2x 100 06 & also a 130 06. All of whitch are built on the same running gear as a 80 05.
Bernhard
07-12-2002 00:25:45
Hi John,
sent You a mail with technical data about the D 8005, if it hasn't arrive, please post it here, I try again. The D 65 was not a german Deutz, maybe a Tractor from Argentina, or is it a Crawler? It also could be a D 6005, to fix it out I need further Informations.
Bernhard, Derichsweiler, Germany
John Nerw York
07-13-2002 17:35:19
 Re: Re: Deutz 80-05 and D-65 in reply to Bernhard, 07-12-2002 00:25:45
Thanks Bernhard for the 80-05 info. was it only built in 1965 and 1966 or do you mean 1955 to 1966. I had another man tell me 1955 to 1963. As for the D-65 I have a D-50 that has Deutz all over the tags and all tags are in German so I would think it would be made in Germany and the D-65 would be part of that series. Any comments please. John
Bernhard,
07-14-2002 02:36:02
 Re: Re: Re: Deutz 80-05 and D-65 in reply to John Nerw York, 07-13-2002 17:35:19
Hi John,
the 8005 was only built 1965-1966, before that the started at Deutz in the 80 HP-range with the D 80 in 1964. The biggest Deutz Wheel-Tractor in the 50' was the F 4 L 514, with a 4cyl engine and 60HP. Could it be that the other Deutz is a D 55?
For Export the gave more Power to the D 50. Maybe You could post a pic of the tractor, or of the Tags. It could help me identify the Tractor.
Woodbeef
07-14-2002 05:45:26
 Re: Re: Re: Re: Deutz 80-05 and D-65 in reply to Bernhard,, 07-14-2002 02:36:02
Hey guys a D65-07 was available here for 1983 & 84. It had the 230 C.I. engine and 60 pto hp. Could this possibly be the one?
Bernhard
07-15-2002 01:25:34
 Re: Re: Re: Re: Re: Deutz 80-05 and D-65 in reply to Woodbeef, 07-14-2002 05:45:26
that is a possibility, but than there must be written on the side 6507.- Also is the Design another, the 8005 is nearly 20 yrs. older.
