Belarus 562 power steering
david
07-22-2002 19:30:31
my 562 is a little slow in the power steering dept. and it feels like it has a hard place when you turn the wheel sitting still.Where do I check the pressure from the pump?I've also noticed the shaft that comes out the bottom of the power steering unit moves up and down when I turn from stop to stop.Adjustable or rebuild time? Thanks, David Also I have a 505 that seems to be growing some sort of "moss or algae" in the fuel tank. I fuel both tractors out of the same tank work them under the same conditions and store them outside side by side. The only differance is the 562 has a cab and the 505 doesn't. Thanks again, David
Hickory Wind
10-08-2002 14:16:45
 Re: belarus 562 power steering in reply to david, 07-22-2002 19:30:31
My 562 did the same thing! Now it doesn't do anything! I was lucky enough to get it back into the tractor shed.
The steering wheel and steering shaft turn, but the wheels do not move at all. Please let me know if you hear of any remedy. This is plenty of fluid in the hydraulics.
