IXB3 camshaft timing
Doug
08-07-2002 18:29:10
I need help to time the camshaft on my IXB3 Hercules. Lining up the marks didn't work! Anyone have a picture of how the marks are suppose to look? Thanks!
Larry from Maryland
08-08-2002 09:43:03
 Re: IXB3 camshaft timing in reply to Doug, 08-07-2002 18:29:10
The book says to line up the two punch marks on the gears.There are other marks on the cam gear don't use the letters.
Doug
08-08-2002 13:27:35
 Re: Re: IXB3 camshaft timing in reply to Larry from Maryland, 08-08-2002 09:43:03
Thanks, there is only one punch mark - very faint - on the cam gear. Nothing on the crank gear except the "s". I heard they made these to run either direction, maybe this one has parts of each?
Larry from Maryland
08-09-2002 09:13:24
 Re: Re: Re: IXB3 camshaft timing in reply to Doug, 08-08-2002 13:27:35
The mark on the crank gear should be in line with the key.
Doug
08-12-2002 05:12:41
 Re: Re: Re: Re: IXB3 camshaft timing in reply to Larry from Maryland, 08-09-2002 09:13:24
Found it! Very faint, but I was able to line it up and it will run now. Thank you so much for your help.
