Oddball rototiller
Gary Frarck
08-18-2002 11:15:23
I have an old rototiller with the single name of
"Mang" barely showing on it. Does anyone have any information on this machine, please??
The machine looks heavy duty enough to till rocks and has a Wisconsin AE engine.
Jim Tofflemire
09-02-2003 14:00:13
 Re: Oddball rototiller in reply to Gary Frarck, 08-18-2002 11:15:23
I have an old Mang rototiller with a Wiscosin engine I,d like ti find a head gasket for it Does anyone have any info on this Thanks.
Brian Watts
12-21-2003 14:19:32
 Re: Re: Oddball rototiller in reply to Jim Tofflemire, 09-02-2003 14:00:13
I also have a Mang Tiller. Wondering if you ever got a source for parts off your listing?
Help,I need parts.
Gary Van Hee
05-03-2004 13:08:36
 Re: Re: Re: Oddball rototiller in reply to Brian Watts, 12-21-2003 14:19:32
I am in need of some tines for my Mang tiller. Any idea where parts can be bought?
John
10-15-2002 22:20:14
I have tiller that I use. Mang Jr. on the side of it. has a 8hp briggs on it. HEAVY AS A , well you know. Mang was a U.S. built I,m told. Some one on the graden tiller forum gave me this info. If you can hold it ,it will till a hole straight down. I think it might have been Donald at rototiller@hotmail.com. He said that you could get parts until about a year ago ,they just disapeard.GOOD LUCK !!!
Ron
05-29-2003 06:58:10
 Re: Re: Oddball rototiller in reply to John, 10-15-2002 22:20:14
I have three Mang tiller bodies and a box of new parts such as gears shafts and seals etc.
Jamie Langan
05-31-2005 12:39:25
 Re: Re: Re: Oddball rototiller in reply to Ron, 05-29-2003 06:58:10
I have a Mang Jr. with a need for some bearings (for both sides of the tiller itself) and recommendation for an exhaust. Before I got it, someone put an 8hp honda motor on it (which runs great) It tilled all last year, but found that someone drilled the casing and bolted the tine shaft in place. Of course, the machine destroyed the bolts and the bearings are pretty shot. The one side still has the bolt going into the gear arm (right side) but the left side has also sheered off. If you happen to still have any parts, I would greatly appriciate any consideration or recommendations. What weight of gear oil would you recommend as well?
Thanks,
JAMIE
paul
06-06-2003 09:40:33
did mang disappear? i need parts!!!!
Ron
06-09-2003 03:48:15
 Re: Re: Re: Re: Oddball rototiller in reply to paul, 06-06-2003 09:40:33
Paul,Yes unfortunatly Mang quietly slipped away and we are left holding on to our Mangoes.Seven years ago I bought a group of mangs so that I could keep my tiller running for ever.I haven't had to use any parts yet probably because I learned the limits of it's use.So I am willing to part with some parts.Ron
MIKE GALBALLY
12-02-2005 10:41:12
 Re: Re: Re: Re: Re: Oddball rototiller in reply to Ron, 06-09-2003 03:48:15
hI, WE HAVE A MANG JR TILLER 8HP
WE NEED 8 RIGHT KNIFES AND 8 LEFT KNIFES
IN OTHERWORDS THE TINES OR BLADES. iF YOU COULD HELP US WITH ANY INFO. THAT WOULD BE GREAT!
OUR PHONE IS 215-784-7090
Arnold Nelson
07-01-2004 17:24:58
Ron, Do you have a ramp plate for the tiller shaft? It is a mushroom shaped piece, about 7" wide with 2 big holes. I broke the original. For anyone interested, I have a 12 page mini manual put out by Mang. Only somewhat helpful in tearing into the main gears but better than nothing.
Kevin Hagan
07-18-2005 13:04:48
 Re: Re: Re: Re: Re: Re: Oddball rototiller in reply to Arnold Nelson, 07-01-2004 17:24:58
I have a friend who is in need of any information dealing with a Mang Jr. rototiller....Could you please email me with a copy of you 12 mini-manual or any other relative information....Thank you for your time and effort..
Jamie Langan
05-31-2005 12:38:01
I'd love a brochure...if you could scan it or fax it that would be great.
Bill Nichols
05-11-2004 10:01:38
Hi Ron-
Do you still have any parts left for a MANG rototiller? I desperatly need a final drive chain cover. Also need other driveline parts if you have any.
Al
06-29-2003 22:11:24
Parts problems!!Yeow. I just bought a very large Mang tiller, it has a Wisconsin motor on it. I was told it runs good but doesn't move on its own power. It has a drive lever that pulls/pushes a rod which comes out of a rectangle shaped gear box mounted under the motor. Might anyone have any info on this beast of a tiller?
T
