Plymouth / Silver King help!
tractordan
08-22-2002 05:26:44
I'm putting the final touches on my 1934 Plymouth tractor, and need some info. First, what is the correct carburetor for that engine (Hercules IXA)? I also need the governor spring, the one on it is quite pitted. Last, I need an air cleaner. I have the gooseneck part that turns down from the dashboard, but thats it. Anybody have one or know where I can find one? Thanks!!
Dan
D Smoker
08-28-2002 15:39:18
 Re: Plymouth / Silver King help! in reply to tractordan, 08-22-2002 05:26:44
The zenith 193 1/2 carb with the tag no. 7776.
Good luck finding one. If you find one you can't get parts for it. Only made a few years before replaced by the 161 series carbs. The 193 1/2 doesn't even show up in parts books any more.
We had to make the gaskets for ours and very carefully dis-assemble and clean it.
Larry from Maryland
08-22-2002 09:10:58
The parts book lists a stromberg carborator,I can look tonight for a model#.If you have tru-value hardware store around you can take your spring and compare it to the ones they sell.They used 2 very differant springs,see my earlyer posts.They allso used many differant air cleaners and the book does not give a serial number breakdown.The pipe is differant depending on which air cleaner you have.
Larry from Maryland
08-22-2002 18:22:10
 Re: Re: Plymouth / Silver King help! in reply to Larry from Maryland, 08-22-2002 09:10:58
Oops made a mistake on the post above.The parts book shows a zenith 193 1/2,but then it says be sure to use the number on the tag on the carb when ordering parts.
