Need info on Construction King year and manuals
Bill B
09-12-2002 17:51:59
Recently purchased in estate sale a Case Backhoe called a Construction King It was sandblasted and painted so numbers are scetchy.
Modle #42 on both hoe and operators plate Serial # on hoe 4059572 and on operators 4868676 or the 7 could be a 1 plate on gas 4 cylinder engine is GWC K 30
Would like info on year, fluids, and where I could get an operators and repair manual in Ontario or Canada you can e-mail me at bunt@vianet.ca
manuel
09-18-2002 14:55:09
 Re: need info on Construction King year and manuals in reply to Bill B, 09-12-2002 17:51:59
Bill,
there were lots of versions of the Construction King. There was even a Comfort King made by Case.
More info on the model would probably help identify the machine. the manuals are still available.
hope this helps. Manuel
Bill B
09-15-2002 14:31:55
 Re: Re: need info on Construction King year and manuals in reply to geok, 09-15-2002 04:47:51
Thank you for the approximate year. I tried the website for manuals but it comes up negative
What do I call this, A Construction King Model 42:
Case 42
etc, I am lost as Cann't find any info at all
OldFarmBoy Jim
10-10-2002 10:17:25
 Re: Re: Re: need info on Construction King year and manuals in reply to Bill B, 09-15-2002 14:31:55
Bill,
I'm no expert, but I'm working on bringing a Case 380 Construction King back to life. It turns out to really be a David Brown 885 Industrial. Case bought David Brown at some point in time. If this is a David Brown, check to see if there is a data plate on the right fender about knee level. The second line starts out with the model # and version then gives the tractor serial #. The third line is the engine serial #. There are several good DB sites on the web. Try primedia (I&T shop service manuals) for thr best prices on manuals. Good luck,
Jim
