Radiator hose
David B
09-26-2002 03:43:43
I need to find a lower radiator hose for an Avery tractor. It is almost a straight hose but has about a half inch offset in it. Are these hoses avalible?
Alberta Mike
09-26-2002 10:00:18
 Re: radiator hose in reply to David B, 09-26-2002 03:43:43
I cut a 12" section of hose from the top radiator hose from a Dodge truck V8 and it worked fine, and it only cost me 50cents at a parts yard. It had a little offset kink in the section I cut out and it worked fine and cleared the steering column shaft OK. It was the next size smaller diameter but it did go on with a little coaxing and it looks nice. I have a history page that I've made up on these tractors that I could email to you if you want, just contact me via the blue email name link above and I'll send one to you.
