Old Silver King
Rodney
09-27-2002 08:17:47
I know very little about the Silver King brand, but I know where an old tri-cycle SK is sitting (very rusty and probably more of a project than I can afford but...) I was wondering where I can find the model number and what kind of problems there would be in restoring it. It's rough, real rough, but I swear it cried out to me when I saw it sitting there in the brush. It's fairly complete, but probably hasn't moved in 40 years...
Thanks.
Craig
10-07-2002 19:56:31
 Re: Old Silver King in reply to Rodney, 09-27-2002 08:17:47
I have found a silver king all torn apart,I know nothing about it. I don't know the model #,but it looks to be a small tractor.It has a wide front end ,and was torn apart for motor work.The person lost intrest and left it sit. I would like to know how hard parts are to find. Any information would be helpful.
Larry from Maryland
09-27-2002 08:52:33
They have a brass plate on the transmission it can be on either side.As far as problems go manifolds rust out and often water gets into the trans/rear this rusts bearings and gears,plus it often splits open a crack and lets out all the gear oil.Don't forget engine a raditor cracks too.Most engine parts are common with avery and cletrack, most other stuff has to be made or taken from other silverking tractors.The R66 is the most common seen 3 wheeler.
Alberta Mike
09-28-2002 17:44:02
 Re: Re: Old Silver King in reply to Larry from Maryland, 09-27-2002 08:52:33
You mentioned engine parts common with Cletrac and Avery. Didn't the Silver King's have Continental flathead 4-cylinder engines?
Larry from Maryland
09-29-2002 14:04:25
 Re: Re: Re: Old Silver King in reply to Alberta Mike, 09-28-2002 17:44:02
After 1940 or there abouts they went to the continental engine.The old ones used the Herk either IXA or IXB.They did use a differant govner than the avery's.I am a long way from canada but my friend just cut up an avery and I got the rods to fix my silverking.
