Long 360 final drives
Bus Driver
10-01-2002 17:23:37
When new, my Long 360 would sling lube out the vents on the final drives. I stuffed the vents with bits of cloth towels in the hope that it would still vent satisfactorily. Apparently worked well till recently. Anyone else seen this problem and how was it solved?
marv
10-01-2002 21:23:58
 Re: Long 360 final drives in reply to Bus Driver, 10-01-2002 17:23:37
Proper vents are available from your Long dealer (I am one). They go in the top hole in the final drive housing. The lower hole is for oil level check.
DOUG
10-21-2002 17:00:26
 Re: Re: Long 360 final drives in reply to marv, 10-01-2002 21:23:58
Marv I have a 440 LONG with 3cyl diesel Motor was run out of oil lokking for a used one and a local dealer. I live in northern Ill. Thanks for any help. DOUG
