CAST MODEL 435L
R.Reid
03-16-1999 20:09:45
DOES ANYONE HAVE ANY INFORMATION ON A "CAST" MODEL 435L TRACTOR. ITS A FULL TIME FOUR WHEEL DRIVE TRACTOR THAT LOOKS LIKE A SMALL LOG SKIDDER.IT HAS A DUETZ DVA 1500 T GAS ENGINE.I THINK IT WAS MADE IN ITALY. ANY INFORMATION WOULD BE APPRECIATED.
Max Koone
03-28-2003 22:10:09
 Re: CAST MODEL 435L in reply to R.Reid, 03-16-1999 20:09:45
Note address change.
Max Koone
11-17-2000 17:06:46
Im starting a register on the CAST tractor to distribute/exchange information on these unique tractors. Contact me at mkoone@grits.net for more info.
nees paul
09-25-2005 03:28:26
 Re: Re: CAST MODEL 435L in reply to Max Koone, 11-17-2000 17:06:46
I'm restoring a cast435L, but I need an owners manuel. I also need parts to repair brakes and other things. Can somebody help me?
James Royal
11-15-2001 08:57:22
I own a Cast 435L I am Looking for any information I can find about this tractor
It has a 32 horsepower diesel engine
chassis 010340
RMR
02-23-2006 08:10:05
 Re: Re: Re: CAST MODEL 435L in reply to James Royal, 11-15-2001 08:57:22
Did you find any info? I own two that I"m wanting to sell but have no idea what they are worth.
Roger
Peter Gibbons
04-24-2005 13:04:25
I have a Cast 435L which is usable but I want to do some work on it. Unfortunately, I have no manuals and I have no information to contact someone who knows about it. Any reply appreciated. Pete Gibbons, Putnam Valley, NY
chris horne
10-05-2000 19:07:22
I have a cast430 trac. with many extra parts and manuals
they were made in italy for vinards and orchards.
I have found no sourse for new parts. Send me your e-mail
Peter Gibbons
04-24-2005 13:11:48
 Re: Re: CAST MODEL 435L in reply to chris horne, 10-05-2000 19:07:22
I would really like to purchase a Xerox copy of your Cast 430 tractor.... hoping that it is related in some way to my 435L. Thank you
Les Greenstreet
03-14-2000 20:57:07
have cast 430L 4wheel drive 4 wheel steering 2 cylender diesel engine have very little informatiom give me a call at 907 745 2536
Max Koone
10-27-2000 18:29:08
 Re: Re: CAST MODEL 435L in reply to Les Greenstreet, 03-14-2000 20:57:07
Are you sure this is a duetz engine? the model number sounds like a Slanzi engine.
Kelly Williams
01-23-2005 07:38:15
 Re: Re: Re: CAST MODEL 435L in reply to Max Koone, 10-27-2000 18:29:08
I have one these tractors with the slanzi engine . It has a forklift attachment ,loader attachment and three point attachment that the arms are missing. 8 forward gears, 8 reverse and a reversable PTO output shaft, 7.50 x 16 inch tires, all the sheet metal and 2 cylinder air cooled diesel that looks like a duetz. It also has compression release for cold weather starting.I have found that some pickup parts will enterchange with some slight modification.
RMR
02-23-2006 08:03:30
 Re: Re: Re: CAST MODEL 435L in reply to Kelly Williams, 01-23-2005 07:38:15
Do you have any idea of what these tractors are worth? I have one with a front loader and also one I use for parts. I am wanting to sell them but have no idea of their value.
rmr
Frank C. Vlossak
04-11-2007 14:21:33
 Re: Re: Re: CAST MODEL 435L in reply to RMR, 02-23-2006 08:03:30
I have a friend that has a cast - he needs a universal joint for one of the wheels - any suggestions?
warren Baldwin
02-20-2005 08:12:31
We have one of these bought in the mid 70's and need parts or advice on where to get parts please reply
Peter Gibbons
05-02-2006 08:30:45
 Re: Re: Re: CAST MODEL 435L in reply to warren Baldwin, 02-20-2005 08:12:31
I am now gathering information to locate manuals and parts for the Cast 435 ... and I will need plenty of advice. Have you had any success in locating manuals or advice? Any reply appreciated. Peter Gibbons, Putnam Valley NY.
Bernard Chrzanowski
07-21-2002 16:08:19
I have a Cast tractor 435L in running condition that I use. I have no method of getting parts for the above. It also has a Slanzi engine Motor # 135390. Also looking for a place to get parts for it. It is running now but is getting old.
Bernie
Max Koone
10-12-2000 21:50:56
For Slanzi diesel parts contact; Lombardini U.S.A., 60l Old Norcross Place, Suite E, Lawrenceville, GA 30245, Phone 770-623-3554. They will refer you to nearest dealer/distributor. Hope this helps. For Duetz try your public library for Duetz-Allis address, tell them they make construction machinery and diesel engines as well as gasoline engines.
Max Koone
12-02-2000 15:22:15
 Re: Re: Re: CAST MODEL 435L in reply to Max Koone, 10-12-2000 21:50:56
The address for Lombardini, U.S.A., Inc., has changed. It is now 2150 Boggs Rd., Bldg. 300, Suite 300, Duluth, GA 30096. Phone 770-623-3554. They will not sell you parts but can tell you the nearest Lombardini dealer to you where parts can be ordered. I now have a register going on the CAST. E mail me with your USPS address for information sheet and registration info.
Max Koone
10-01-2000 19:33:14
I have a 430L non export model with Slanzi diesel engine, maintenance and parts book for export models and Slanzi parts and service manuals, advertising manual as used by salesmen and address of an owner with three tractors. He supplied the copy of maintenance and parts book for export model which I have. Slanzi parts are available in US.
Ray
03-12-2000 08:30:19
Have you had any luck in your serch I am looking for some info on a 430L. It sounds like almost the same tractor except the one I have is a diesel. any info would be helpful.My e-mail is honeybee@presys.com thanks.
pat
09-26-2003 11:36:47
 Re: Re: CAST MODEL 435L in reply to Ray, 03-12-2000 08:30:19
I have the manuals and specs curently rebuilding drive train through a machine shop got all the bearings so far. almost done. looking for attachments.
